RCU Forums - View Single Post - Need to order a part--can't remember what you call it
Old 05-07-2005 | 05:17 PM
paul_c
Default Need to order a part--can't remember what you call it
Guys, I'm experiencing some brain fade. I need to buy the tiny "thing" that allows me to connect the metal wire that controls a control surface (e.g. elevator) to the plastic horn on the servo. It has a screw that tightens onto the wire (one would use this instead of a Z bend). I need to order some very small ones to fit a HS-35 servo (sub-micro servo). Can't order it if I don't know what these pieces are called. Hope I gave you enough of a description.
