Need to order a part--can't remember what you call it
NJ
Guys, I'm experiencing some brain fade. I need to buy the tiny "thing" that allows me to connect the metal wire that controls a control surface (e.g. elevator) to the plastic horn on the servo. It has a screw that tightens onto the wire (one would use this instead of a Z bend). I need to order some very small ones to fit a HS-35 servo (sub-micro servo). Can't order it if I don't know what these pieces are called. Hope I gave you enough of a description.
ok, I looked on tower.
Different brands call them different things.. I saw
Dubro E/Z Connectors
Great Planes Screw Lock connector
Sullivan pushrod connector
Just go to Aircraft accesories/control linkages/Pushrod Connectors and you will find them.
NJ
You guys are too quick--just ran upstairs to look at a book--pushrod connector. ugg. Thanks all, love the speed of the help on these forums. Now I have to find ones small enough for an HS-55 servo.
My Feedback: (31)
TX
Dubro makes a bunch of small stuff for parkflyers. Check their online catalog for mini-EZ connectors or use the micro ez links.
Duke
Duke
