RE: Tiny tip when fueling your plane
Same as guys never had that problem, i just use a piece of brass tubing inserted one end into the tubing from the pump then just pull the tubing off the carb and insert the brass link... Always get a good tight fit, maybe you could try larger diameter brass tubing link?
