RE: crash
had my budda send my motor in today, and as far as picts dont know how to show pics, used 7ch/7cap trans 2-5945s on ail 2 on
elevator 1-5955 on rudder pull-pull ,1-3004 on throttle nun on choke ,no metal to metal connections strapped 6volt battery under servo
tray reciever above on top of servo tray antenna was drilled through the bulkhead out and down the belly couple inches from c/f rear
gear.ignition strapped to inside engine box onleft fire wall,ignition batt mounted outside, engine mounting box,on right side.
one JR H/D switch mounted on right side just behind canopy,same switch on ign, mounted in forward mounting hole on same side.
checked switches ,still working. 1024 pcm reciever ,running y harness for dual elev servoes.ran 6volt reg for reciever.
