ORIGINAL: joesabido
I want to change the color scheme of my WM Mentor, the cowl is fiberglass already painted.
What kind of paint should i use?
>I would recommend an acrylic enamel (fuel proof ), although
>any type of paint will work if you primer the cowl first and if
>needed, clear coat it afterwards.
Do i have to remove the old paint?
>It depends on what shape the old paint is in AND what type of
>paint you plan to put on.
>The MAJORITY of factory painted parts are done in enamel.
>If you plane to put a lacquer over it, you either need to strip the
>old paint off or put a primer over the old paint.
>If the original paint is in decent shape AND you will be using an
>enamel paint, just sand the surface with some 320 or 400 grit
>paper, then THOROUGHLY clean the cowl with ALCOHOL, NOT
>PAINT THINNER OR LACQUER THINNER. The thinners WILL affect
>the underlying paint. Depending on the underlying color, you
>should be able to paint right over it since the sanding will give the
>new paint something to "bite" into. If you will be going over a
>dark color with a lite color, you may want to shoot a THIN coat of
>WHITE primer OR a THIN coat of silver first.
>If you plane to remove the old paint, BE VERY CAREFUL ABOUT
>USING STRIPPERS. Many of them WILL AFFECT the fiberglass.
>I suggest sanding the old paint off if you want to remove it.
Any advice is wellcome [&:]
If you will be doing any masking, I suggest using the 3M brand blue masking tape. What you want is the "60 Day Safe Release", not the 14 day safe release. The 60 day can be identified by a "paper" appearance, not textured, and on the side of the plastic wrapper there is an adhesive index. You want the "2 dot" adhesive rating. The 60 day release tape will not pull up underlying fresh paint. As with any masking, I suggest sealing the edge of the tape with a clear prior to painting to prevent/minimize any "bleeding".
Hope this answers your questions.
