RCU Forums - View Single Post - Anyone Flying a Magic Extra Yet?
Old 06-26-2003 | 06:18 PM
  #207
Flyn_Hawaiian
Default Magic Extra .... just finished mine
I'm flyn this baby... when the weather allows.
Thanks for all your comments on this arf.
4.75 lbs finished.
OS46FX
Belly pan was an 1/8 inch too long. Wing bolts were not alligned properly and replaced them with 1/4" nylon. Engine mount holes were also not alligned properly, reamed out the motor mount to make it work. Replaced stock main wheels with Dubro 2-3/4 light foam ones and they fit nicely into those off color molded wheel pants. Replaced the maroon spinner with a Dubro (better color match). Used a Sullivan 8 oz. rectangular flex tank instead of the one supplied. Added a third fill drain line to the tank because the spacing of the 46FX and the 4" thrust washer from the fire wall measurement makes a tight fit.
CG at about 4.5 ...... if everyone else that has flown this bird with the CG there.. i'll give it a try too.
I also coated all the black stripes with clear dope in hopes that they won't peel off.... at least until the 3rd flight. LOL.
It was alittle more work getting this ARF together than my GP Venus40 ARF.... hope she flies good.....
