Anyone Flying a Magic Extra Yet?
The range check with the engine running is how I found the problem, and ALL servos are affected at the same time. All of the control surfaces just start moving erratically. Gets worse the farther away I get, but will do it fairly close with the antennae down. I'll check the crystal, and try the rubber band on the throttle linkage also.
