Tower 46
Most likely it is in the carb. I ran into the same issue with a Moki 1.35. Not a major problem, but annoying. You can try sealing the carb seat, it may help. If you have any other 46 size carb, try swapping it and see if that is the problem. Otherwise, you can do as I did-just live with it.
