RE: NX vs Mejzlic
Outright thrust--
static?
the 32x8 size is good on a lighter model - I run the JAS-a wooden copy of the Mejslik also the 22x8 Mejzlik also the new Skorpa props -made by JAS to his specs.
Using a decent exhaust -(Iuse the AMT pipe )power jumps way up to low 7000 range on the 23x8 and into the upper 7000 range on 22x8 props .
The incowl mufflers will be considerably less.
So thrust is not specific to a prop --it is the whole setup
