RCU Forums - View Single Post - Excelleron 50 Electric
Thread
05-12-2005 | 06:35 AM
2
David Gibbs
Oct 2003
82
Camberwell, AUSTRALIA
RE: Excelleron 50 Electric
First to the insides and control linkages. It comes with 'standard' small model approach of a single servo tray with the two servos side by side and pushrod with 'V' split at the back for the elevators. Much as it probably doesnt make a huge difference on a smaller model, I happened to have a DEPS setup out of a 2m model that met an untimely end that was easily cut down to size. So I set about separating the rudder and elevator servos and putting them on separate trays so the linkages were centred. Given the location of the stringers and construction of the fuz this was easier than I thought.
The battery pack between them is just for receiver/servos. It needs to be back here as the motor batteries sit right up in the cowl for easy access. Given it is a one piece wing I wanted the motor batteries easily accessible without having to take off the wing.
Here are the insides and the control linkage exits.
Reply
Like
David Gibbs
View Public Profile
Send a private message to David Gibbs
Visit David Gibbs's homepage!
Find More Posts by David Gibbs
View iTrader Profile
