RCU Forums - View Single Post - Excelleron 50 Electric
Thread
05-12-2005 | 07:25 AM
7
David Gibbs
Oct 2003
82
Camberwell, AUSTRALIA
RE: Excelleron 50 Electric
I struggled with the motor mount for a while (meaning I replaced it and it came straight out again, then did it again so it didn't come out, and it delaminated the ply plate it was screwed to!)
The final install has aluminium brackets running through the nose plate, and screwed firmly to the motor mount bearers, and a 2mm carbon fibre plate in front ensuring nothing can move, along with additional screws and lots of focus on a good epoxy joint all round. You can see the changes in the photos below compared to the earlier one.
I also opened up the opening in the front of the cowl and put in a baffle to split an air stream to aim straight at the motor while leaving the balance to flow over the batteries and out (both through the bottom of the cowl, but also out through the fairing under the wing).
Reply
Like
David Gibbs
View Public Profile
Send a private message to David Gibbs
Visit David Gibbs's homepage!
Find More Posts by David Gibbs
View iTrader Profile
