RE: Mini Funtana + OS15 = Awesome little plane!!
I think it would be tough to use standard servos in this plane. You could get away with the rx, likely, but the servos are way bigger than it was designed for. Unless maybe if you ripped it apart and installed them in the wing area somehow. just doesn't seem like a good solution though. Spend the $80 bucks (shop carefully) on some Hitec HS55's
