RCU Forums - View Single Post - Dave Patrick super cub
Old 05-14-2005 | 09:39 PM
  #476
orvel's Avatar
orvel
Default RE: Dave Patrick super cub
Thanks for the pictures Bud. It looks great! Yes! I do mix about 20% rudder with mine and that really helps with the turns. You can also mix in some differential on your ailerons and it will have the same effect. I rather do it with rudder but regardless, you need to do this or else when you bank the Cub for a turn it will sort of yaw and doesn't look right, it's just a characteristic of the Cub. By the way, have you weighed yours yet? With the floats and on wheels? Mine came in at an even 17 lbs. dry and I have a 16 oz. tank!
