RE: Filled Crank
Dave:
With the "standard" crank porting there will always be some turbulence induced by the hard angles and the closed forward end. "Filling" the port is to reduce the turbulence. Seems to work.
You are right about its comiong loose at 22K rpm though, definitely some internal modification to the engine.
Bill.
