RE: Stryker help???
Are the battery connections solid? They tend to get pushed out easily (and they can get loose too). Make sure they are all the way in on both the battery and the plane, then crip them a bit to make sure they get a good connection (needle nose plyer works ok). Sounds like you lost power if nothing at all is happening.
Steve
