Stryker help???
CA
I just got my second stryker and i flew it today for 10-15 mins. As i brought it down the last time, we were checking it out, and NOTHING WORKED!!! It just broke on me. The batt is fully charged and it seams to be fine (no parts missing, nothing broken) but it just doesnt work. Any suggestions/ ideas of things to do or to try???
EDIT: transmiter checks out fine so its most likey a problem with the plane.
Are the battery connections solid? They tend to get pushed out easily (and they can get loose too). Make sure they are all the way in on both the battery and the plane, then crip them a bit to make sure they get a good connection (needle nose plyer works ok). Sounds like you lost power if nothing at all is happening.
Steve
Steve
