Thanks turn and burn.
Looking at the pics I took when I got the engine, it looks like it has no restrictor......at least not visable
Yes Paul, I am very happy with the result. I had too much elevator. Only needed half of the throw I had given it. I had given the full elevator movement until the LE of the stab touched the fuselage when giving full up. It only needs about half of that movement.
Also.....the plastic inside the canopy shrinks in the sun!
I look like a red lobster in my face, so the sun was a bit harsh
If you look at the base of the instrument panels, you can se the plastic has ben distorted. Maybe if you glued some wood or glassed it or something, it wont do this.
