RCU Forums - View Single Post - ROO c.g.
Thread: ROO c.g.
Old 05-16-2005 | 11:04 AM
erbroens's Avatar
erbroens
Default RE: ROO c.g.
Well, I only use the wheel brakes on down elevator, and never had a problem... the only thing that
I avoid is to use the brakes when the nose wheel is still above ground. But if you put the
brake in a slider or a switch it will work fine too.
Anyway, in a good roo landing the airspeed is so low that you will not need to use the brakes at all...
