RE: VMAR MODELS
I have seen carefully almost all the VMAR planes, even some that US distributor does not have. I cannot believe if anyone can really say that the plane is good. Yes, they fly fine but after 10 flights it all falls apart, it is best flown in the dark where there is no sunlight, also do not use any fuel as the exhaust will cause adverse effect on the covering ... if you can please ensure that the motor has no vibration as it will shake everything loose.
Its a pretty good plane I guess ...
I consider Black Horse planes to be cheap stuff but VMAR is cheaper!!! VMAR/VQ etc have the same quality issues. Cheap quality ...
