RCU Forums - View Single Post - ROO c.g.
Thread: ROO c.g.
Old 05-16-2005 | 01:38 PM
hornet driver
My Feedback: (7)
Default RE: ROO c.g.
Well, I only use the wheel brakes on down elevator, and never had a problem... the only thing that
I avoid is to use the brakes when the nose wheel is still above ground. But if you put the
brake in a slider or a switch it will work fine too.
Anyway, in a good roo landing the airspeed is so low that you will not need to use the brakes at all...
grass is easy
300 flights on the Roo with down elevator brakes and I have yet to see the mains lift, nor on any of the other 1200 turbine flights with my other airplanes. And I do fly in heavy winds in the desert. Land on speed
oh they are lifting.....
and your 1200 turbine flights with other planes is mute....as i assume they were not all delta..duh...airframes do wear out if you can keep them up for 400 flights
and heavy winds...well no shi$....nothing like a 17 mph head wind to slow you down
you guys are cracking me up
hornetdriver
you guys are crackin me up
