RCU Forums - View Single Post - pinning ca hinges
Old 05-17-2005 | 09:13 AM
Campy's Avatar
Campy
Default RE: pinning ca hinges
That is how I pin my hinges.
FWIW - Cut a small slit in the covering prior to drilling the holes. Then make the "pins" slightly shorter than the total thickness of the surface being pinned. Insert the pins and CAREFULLY PUT A DROP OF THIN CA on each side. Now iron the slit closed over the pin.
