RE: Winter Project Complete - BTE Flyin King
Hello Mimhoff,
If you can't see the pictures, let me know and I will email them to you.
The airplane was built like a trike with four inches wheel all around. In the front, however I used the FULTS dual strut landing gear. It gives , I feel , better ground handling. The tank was a 14 ounce Dubro. The plane came out a little nose heavy and I had to use a bit of lead weight in the back. The OS 91 with a 14X6 inch was more than satisfactory to pull the plane. I used regular JR servos (537). The instruction are well written and I did not deviate a bit from them.
Good Luck
