RE: Tail touch hovering technique
one other thing to think about if you do indeed get it almost touching... dpeending on the situation if you are about to loose it within inches of the ground you might be better off cutting the throttle than rather saving it and then it snapping crazy and it's crumpled. most planes can handle a 1-3 inch fall on the tail with little to no damage done if on grass. But fly out and catch a wing and you are toast.
JP
