RE: U-Can-Do as a beginner aircraft?
I agree with rcandy - get your self a Stik (even build it with the dihedral if you can it's not that much) The plane is still a high wing ( a little more stable), but fully aerobatic. Set up with low throws in the beginning , learn how to fly it, then increase the throws. The U-Can-Do is a great plane, but maybe a fourth or fifth plane for experience levels. The Stik is a great trainer for primary aerobatics, and will win at fun-fly's once you feel comfortable. Plus, it won't break the bank for costs. I've had about five of them and curerntly have one now that was given to me. Plust the good ole Stik is a tough as nails bird that is easy to fix if it gets broke and lots of room to install the electronics is. I've even seen some that had flaps. Good Luck
