RCU Forums - View Single Post - Removing wing-warps
Old 10-05-2002 | 01:37 PM
Flypaper 2
Default Removing wing-warps
You'll brobably have to remove the bottom sheeting, check to see if the warp is still there.If not, pin down level and resheet. If it is still warped shim it so it slightly warped in the opposite direction, pin it down and resheet. This is just one method.
