RCU Forums - View Single Post - NEMESIS4U's SHERMAN FULL FUNCTION BUILD
Old 05-24-2005 | 02:17 PM
  #51
narcop
Default RE: NEMESIS4U's SHERMAN FULL FUNCTION BUILD
NEMESIS4U, hello again. Instead of using the JR equipment I bought the Futaba Skysport 6 75MHz. I took the almost finished sherman for a test drive. During the test I could not make the main gun fire. Even more confusing is, the tank shut off then started back up and the main gun fired with the recoil going foward instead of back. Alson the machine gun and the lights activate O.K., but I have to use different trims and stick moves. [] Have you or anyone else had this problem? If so, what is the fix?
Thanks for your help,
Chris
P.S. I'm going to post pics of the tank later.
