RCU Forums - View Single Post - Rough thrust bearing.
Old 10-04-2002 | 06:47 PM
RS2K
My Feedback: (8)
Default Rough thrust bearing.
Originally posted by Culverson
Very possible is that its shifting (slack) thus changine everything. I had a Nexus long ag you could fly it and the tracking was perect. But after you sat it down and hover again my tracking was out of wack.
Check:
Thrust bearings installed backwards---CHECK - They are fine.
Loose bolt in head---CHECK - I thought that was it once.
Check Head Block Condition---????? How can I tell?
Lube & chk. rubber dampners---CHECK New ones AND they are lubed
Bearings In Blade Grips---CHECK One bad thrust bearing - missing a BB.
Swashplate wear---CHECK No wear
I have have a bad thrust bearing for sure. I just wanted to see if maybe it was something else. The other bearings in my head are A-OK.
