RCU Forums - View Single Post - 3Dfoamy.com F-18 setup question
Old 05-24-2005 | 09:22 PM
vicman's Avatar
vicman
My Feedback: (10)
Default RE: 3Dfoamy.com F-18 setup question
mounted on the motor with the prop FACING
the front of the plane
The front of the prop should face the front of the plane and then you will run the motor backwards. C gearing is 5.33:1 or the 64T gear set. I run my antenna out the front of the inlets and hot melt glue it to the side of the fuse. The CG is 2.38 back from the inlets or 3.87 from the front of the wing where it hits the fuse. Indeed a little forward of the spar.
ID:	276171   Click image for larger version
ID:	276172   Click image for larger version
ID:	276173   Click image for larger version
