RE: Smoke in the Turbine duct P-80
OK sounds good, just make sure you do not get ANYTHING down that feed pipe when taking the tubing on and off, make sure you do not "slice" off a bit of the inside of the plastic tubing when you put it back on.
Good luck,
Matt
