Hi!
You should have a pressure line from the exhaust pipe going to the main tank. When you crank the engine the pressure from the exhaust pumps fuel to the carburator. Try to remove the fuel line from the carburator and crank the engine a few turns and you should see some fuel come from the fuel line. For tips about raptors go to:
www.raptortechnique.com
/Pischla
