RE: choke ssembly
Keep in mind that on the TT .91 the choke has a venturi that is smaller than the carb bore and it improves the fuel draw. The others are the same or large bore as the carb. The only advantage they have other than the choke is that they act as a short velocity stack, which will reduce the amount of fuel mist blown out of the carb.
