RCU Forums - View Single Post - Enya 50 info....
Old 05-29-2005 | 04:55 PM
palve's Avatar
palve
Default RE: Enya 50 info....
Petty:
A 2-stroke like this is pretty simple. If you dont have any mechanical damages, and can turn the prop around not hearing/feeling anything strange, then cehck this:
1. Do you feel a normal comp.?
2. Is your glowplug really glowing?
3. Do you get fuel through your system?
- Then turn main needle out 2,5 turns, give it some throttle, and it will start.
If you have tried "everything", I guess something obvious/basic is left out. For me, I found the main needle was choked by old fuel. Go over it again, adjust the idle needle and main needle, make sure the plug glows, and start the da... thing.
Good luck.
Pal
