RCU Forums - View Single Post - 80"CAP elevator issues
Old 05-31-2005 | 11:22 PM
budgetdude's Avatar
budgetdude
Default RE: 80"CAP elevator issues
Yes I have been in high rates on the down line. I think I know what the problem is. I used a matchbox to set up the elevator. I also set my endpoints using the MB. My EPA on my radio is 100 percent. I think that because the way my linkage is set it only takes about 50 percent servo throw to acheive the desired surface throw. Since my transmitter is set at 100 percent EPA it is causing my elevator to be super touchy and there is not enough expo to smooth it out. This must sound confusing and I appreciate you taking the time to think about it. I will try using the low rate on a downline to alow more stable pullout.
Did you land this plane with power or do float it in at idle?
