RE: Help with hovering throttle mix
You must use a Point mixer and expereiment to find where place these throttle points on the throttle curve. For instance, if your plane hovers at 1/2 throttle you would want the throttle curve nearly flat around mid-stick. You would then pick the points to make that happen.
