RE: CMP Christen Eagle CG?
hi
u r lucky...
i had the same plain with a g26+smoke system.
1. it is a butifull plain
2. reenforce the lamding gear wood plate..the g26 is too heavy so 1 heavy landing and the gears are gone!!!
3. the cover do not support gasolin!!! the residue from the motor will pill of the cover so either do a new cover,( recomended but more work) or add some monocote/oracover at the side of the exh exit.... u can paint/polish with varnish on the edge of the wings where the cover ends, this way it wont pill off for some time.....clean the AP after each flight from the exh residues....
4. all CMP models have an error on calculating the CG!!!! your CG is in the place where it says in the manual , hover, the g26 is heavy so you will get more nose wight - thats fine for the first flight! later on, move the motor as needed ans add wight to the tail if any????
5. reenforce the 2 screw places for the upper wing !!! on time the screw will penetriat the wing balsa..... just add some 0.2mm wood plate and u r good.
6. u should reenforce the firewall for the g26. the original one is too slim!!!! add a 2-3mm wood plate to the firewall together with a fiberglass cloth all arround glued with a 30min epoxy.
7. usually no vibrations, but add some rubbers to the motor stand to reduce any.
u can email me, and i will send you pictures of my Ceagle together with motor mount, servos etc..
gadix
