hi,
kit was $49, and i recommend
www.*********.com.au for anyparts you need. are you in sydney? cause they also have a store, which is where i go. and its even cheaper again to go to the store. they are the cheapest for anything that i have found.
with acceleration, i got significant improvement, however i am still unhappy with acceleration. my mates HPI RS4 is still getting up quicker than me, so i am considering buying the CTS tuned exhaust, which i hear gives it more horse across the entire RPM range. you lose about 12-15 km/h top end? one thing you need to buy separate from the kit is a 10mm pin. you will find that when you replace the front drive pulley, that the existing pin is too long.
if this doesn't work i might even get the new cen turbo motor? bit of a waste of money, yes. i know. but boys will be boys.
another thing you might like to know about, if you want your car to look good, and be able to drive it at night (now its winter) after work or whatever, i have just installed LED headlights, brakelights and undercar lights on my lambo gallardo shell. anyway, let us know if you want more info.
hope this helps.
