RE: Help with hovering throttle mix
We did some further checking after reading some more posts here.
Use pmix #6 or #7. They allow curves. Turn the mixer on, master is throttle and slave is throttle, link is off, and set the switch position to Null if you want this to operate all the time. Otherwise select the swithc and position you want.
Now go to the page with the curve and set the points where you want them to get the throttle action you need.
For all who've replied, thank you, but please be aware that this support forum is only for people who have questions and for ONLY Futaba support reps to answer. This is not an open forum where anyone can supply answers. If we make a mistake in our answer, it's OK to send a PM to let us know. We'll then fix our mistake. Only original posters can post follow-up questions to their original question. If anyone else has a question, they should start a new thread.
Please be aware that replies to questions by non-Futaba reps will be deleted as we find them. That's RCU's rule for any manufacturer support forum.
Thank you.
