RCU Forums - View Single Post - Here's our trainer! (A work in progress)
Old 06-03-2005 | 12:57 PM
  #55
LSP972
My Feedback: (13)
Default RE: Here's our trainer! (A work in progress)
DuBro and Klett both make small nylon brackets specifically to attach wire to things. You'll probably need the 5/32 size, two per gear leg.
Simply fabricate your tapered gear leg cover from lite ply or balsa appropriately stiffened.
You can use either 2/56 bolts and nuts to attach the cover to the wire, or use a flexible adhesive such as PFM or silicone caulk, etc.
