RCU Forums - View Single Post - Field box plans
Old 06-03-2005 | 03:31 PM
Fastsky's Avatar
Fastsky
Default RE: Field box plans
Or you could just go to Wallmart and buy a plastic tool box for arond $10.00. There are some good sized sturdy boxes for that price. They are fuel proof and don't need paint. Make a cut out in the front for the power panel. Drill out 4 holes in the upper inside tray for the feet of the starter to fit into. Mount a 12 Volt 7 AH battery and an electric fuel pump inside. I also installed a 45 oz. fuel tank inside so that I don't need to open the fuel jug very often. I wired the fuel pump into the back of the control panel so that I could control the on/off and direction from the front of the box. Mine is going on 6 years now with no problems. I have also seen a few tool boxes that are solid flat on top and act as a stool. They are a bit taller and seem to work well too. Depends what you want.
