RCU Forums - View Single Post - DA fixing DA50 lean carburetor problem?
Old 06-03-2005 | 03:33 PM
Antique's Avatar
Antique
Default RE: DA fixing DA50 lean carburetor problem?
Like I have been saying for many years, a larger carb does not usually mean more power..A manufacturer would not intentionally restrict the power by using a small carb when a large one would work better...I suspect the stock carb on the DA 50 would be fine if pilots would not try to use such large props on a relatively small engine...[8D]
