RCU Forums - View Single Post - Scratch built Burrito
Old 06-04-2005 | 07:17 AM
j0rrit's Avatar
j0rrit
Default RE: Scratch built Burrito
Today I've programmed a Elevator-Flap mix on a switch of my T9-CHP (FF9). The Burrito is now able to make 90° turns much easier than before. Ideal to start with a torque-roll at a couple feet from the ground. Only thing is that the ailerons are not responding the way you were used to. Nevertheless a quite cool feature, witch is worth trying.
Up
Down
The settings I use
