RCU Forums - View Single Post - Magic - Maiden Flight
Old 10-07-2002 | 02:59 AM
_shadow_
Default Magic - Maiden Flight
Guys,
I flew the Magic 3D with the following specs,
Engine : OS46SF
Prop : APC 12.25 x 3.75
Servos : 4 x DS8301 + HS-101
Battery : NiMh 1000 4.8V place in the fuse somewhere in the middle
Tank : 6oz, placed on the CG
CG : 5" with 35g of weight in the nose.
Control Deflection : Per Manual on High and Low Rates
Weight : 4lbs
1. I feel the plane is a bit pitch sensitive.
2. It prop hangs at about 1/3 throttle.
3. Not easy to prop hang, I need a lot of practise.
4. Initially the nose was steering to the left, so I added 1mm washers to mount to increase the right and down thrust to correct this.
Regards
Marcus
