RCU Forums - View Single Post - pipework on a gp f-14??????/
Old 10-08-2002 | 02:15 AM
kram51
Default pipe work
That will be a bit difficult as the two areas you want to run the pipes through are where all your servos and receiver are. If anything, you can run it thru the tunnell in between the two exhausts. Even that will be a bit tough to do but significantly easier than what you're suggesting.
Mark
