RCU Forums - View Single Post - the most noob question of all....
Old 06-05-2005 | 04:16 PM
Skullbasher's Avatar
Skullbasher
Default RE: the most noob question of all....
ORIGINAL: s13se
The best way to stop an engine is to put your finger over the opening in the tuned pipe. I heard that pinching the fuel line might over lean your engine and putting your finger over the air filter might push dirt into the carb.
True that covering the filter can push some dirt in, and also true that pinching the fuel line makes it lean. But when you pinch the fuel line, the car only runs lean for a second. You engine will still have enough lubrication on the parts during that second to protect the engine. The reason it is bad to run lean is because the oil is mixed in with the fuel, and if your engine is not getting enough oil on the parts, it will cause premature wear. But if you engine has been running with enough oil to lube correctly, the short amount is time with little to no fuel will not harm anything.
I never cover the exhaust anymore, I always go for the fuel line or flywheel. Unless I just want to run out of fuel.
