RE: Building first kit 4 * 60.
Heres what I found from the Tower Hobbies site.
SuperTigre G-90 Ringed w/Muffler
Bore: 1.803" (27.5mm)
Stroke: 0.976" (24.8mm)
Weight w/o muffler: 589g (20.66oz)
Weight with muffler: 765g (27oz)
Displacement: .90 cu in (14.73cc)
Output: 2.5 bhp at 14,800 rpm
RPM Range: 2,500-16,000
Width between centers of mounting holes: 50mm or 1.97"
Length between center of mounting holes: 20mm or 0.79"
Width of crankcase excluding mounting flanges: 42mm or 1.65"
Length from backplate to front of drive washer: 97mm or 3.82"
Height from bottom of crankcase to top of head: 108mm or 4.24"
Crankshaft size: 5/16-24
Suggested prop size: 12x8, 13x6
I think it has the info you need. [8D]
