RE: DeHavilland Mosquito
I have my Mosquito to the point where I'm ready to balance it. Even with the 46AX's I'll have to add weight, in addition to the 6V 2000mah battery in the nose to get the 4.5" at the wing attach CG. If I go by Spitmad's setting in an earlier post (85mm at the wing root) I'd have to add a ton of weight. I don't see how that could be correct. I may go ahead and do the calculation for the wing so I can determine what the real CG should be. Sounds like some of you have been flying it with success at the 4.5" point, so that is what I'll most likely shoot for.
