Help. Inverted engine with fuel valve... above, below.
Got the engine mounted inverted, and it will be cowled. Carb and fuel tank line up pretty well, so flooding shouldn't be an issue, so where should I put the fuel filler valve??
Can it go above, or below the plane(as in line[not fuel line]) between the tank and carb? How far is too far?
