 Help. Inverted engine with fuel valve... above, below. >
Old 06-06-2005 | 11:12 PM
Default Help. Inverted engine with fuel valve... above, below.
Got the engine mounted inverted, and it will be cowled. Carb and fuel tank line up pretty well, so flooding shouldn't be an issue, so where should I put the fuel filler valve??
Can it go above, or below the plane(as in line[not fuel line]) between the tank and carb? How far is too far?
Old 06-07-2005 | 05:01 AM
piper_chuck's Avatar
My Feedback: (12)
Default RE: Help. Inverted engine with fuel valve... above, below.
If you haven't already bought the filler valve, I assume you mean something like the dubro quick fill valve, consider a fuel dot with a 3 line tank instead. Mount it high enough and with enough slack that you can have the end near the top of the tank. If you are going with the fuel valve I try to put it somewhere between the tank and carb to minimize the amount of fuel line.
Old 06-07-2005 | 07:22 AM
Placing it slightly above or below the normal fuel line run should have no effect. As Chuck said though, try to keep line length to a minimum without kinking.
