RE: Help. Inverted engine with fuel valve... above, below.
If you haven't already bought the filler valve, I assume you mean something like the dubro quick fill valve, consider a fuel dot with a 3 line tank instead. Mount it high enough and with enough slack that you can have the end near the top of the tank. If you are going with the fuel valve I try to put it somewhere between the tank and carb to minimize the amount of fuel line.
