RCU Forums - View Single Post - Icepoint Wing Failure
Old 06-07-2005 | 07:47 AM
Eric.Henderson's Avatar
Eric.Henderson
Default RE: Icepoint Wing Failure
Glenn,
I think Keith was more concerned that the bandage-mention was not in the review, or even that it had editted out. I don't feel that he meant anything else. I thought that I had made it a point in the review. But it is more than possible (most likely) that it is on my end and did not submit the right final file. You are correct that we (you and I) openly discussed and advised people to strengthen the wing join. (Many ARF's are lacking in that critical area).
There is nothing in the instructions about doing it, which is what should be fixed as well. Aslo Ultra-RC should help the guy out here. I will be very surprised if they do not.
Regards,
Eric.
ORIGINAL: HCRCflyer
I also out of habit added another layer of thin cloth on my number 1. You should contact Brian at Ultra RC and I am sure they will work with you to make this right. I don't think I mentioned this in my review.at least on my 2 (early production) the fiberglass is wrapped around the whole wing out a foot total in the center. I was very carefull not to score or cut it when working on it.
Klhoard-
I also rememeber Eric talking about this issue. So If you are accusing him of lying you are dead wrong. It may have been in private email But he has been very upfront about this plane.
Before I Fly my number 2 I will check the wing as I will be recovering it anyway. (and I will take pics.)
